I've used Synology NAS to host my iTunes library for over a decade (currently on DS218+). I use a mac app called Playlist Export to export iTunes playlists to m3u format in a Playlists folder on the NAS. Synology's Audio Station and DS Audio read the playlists without issue (as long as I use the correct export settings).
I'm considering getting a WiiM Pro Plus and wondering: will the WiiM Home app see these exported m3u playlists, or the iTunes playlists, or does it require some other format? Or does it use a proprietary format? (Playlist Export can also export to m3u extended, wpl, zpl, and mpl.)
Thanks!
(BTW, I'm running Synology's Media Server package, and my ancient Marantz pre-pro can see the NAS files and playlists via UpnP.)
Thanks!
