12V trigger between WiiM ultra and Vibelink Amp
I would like to check a few things.
Does the Vibelink LED dim when the device connected to the Vibelink trigger is switched off?
Normally, after 30 minutes of the LEDs dimming, the Vibe will go to sleep and the LEDs will turn off completely; if the device is switched on once during the 30-minute period, it will then go back into standby and sleep again 30 minutes later.
Yes, after 30 minutes, the Vibelink goes into standby mode and the LED dims. But after that, nothing else changes. Even if I completely disconnect Ultra from the power supply and no signal can be sent to Vibelink, the amplifier does not switch off.
Okey
My Vibe is also connected to Ultra, so I will check.
Btw, what happens when you press the standby button on the back panel of the Vibe?
If you press the button once when the LED on the Vibe is brightly lit, it will dim and enter standby mode. If you press and hold the button for 2 seconds, the LED will go off and enter sleep mode.
This works fine, does it?
Also, if you have not already done so, try a factory reset of the Vibe. Press and hold the Standby button for 10 seconds.
Ultra reboots may also be helpful.
Okey
Press for 2 seconds to put the Vibelink into sleep mode 👍 It works manually. I've just started a reset and will check back in an hour.
Mine, connected via trigger to the Ultra, enter in standby mode but never in "sleep".
The led light is always on, dimmed but on.
It's updated and already had a complete restart.
I have only been able to test a few things, but the results are a bit odd.
1) Turning off the Ultra with the remote's power button put the Vibe into standby mode and after 30 minutes the Vibe went to sleep.
2) Pressing the standby button on the Vibe put it into standby mode and after 30 minutes it didn't sleep. It then didn't sleep after 1 hour.
If I am not mistaken, I think it used to enter sleep mode in case of (2).
Tomorrow I will check if the Vibe goes from standby to sleep with Ultra's auto standby.
The problem seems to be solved...
It looks as if a bit has become stuck in the Vibelink. After the reset, the amplifier switches off. 👍
I don't know what programming language WiiM is using but it seems like there has been several cases of issue lately that could indicate uninitialized variables.
