Currently the only way to switch inputs is through the app. This is very slow as one has to find the phone, open the app, wait to find the WiiM and then scroll all the way down in the Browse Menu to select source. Then it takes a further 4 seconds till the command is registered.
I understand there are use cases where the input switching is not wanted. But please, could we have an option to either:
a. Auto switch between sources to the current one playing. If there’s 2 sources playing, then the newest sources gets priority.
Or
b. Make a source “default”. In my use case, the Aux in can be left to default, and when Airplay is used, the source would temporarily switch to Wi-Fi. When the Airplay is stopped, the WiiM mini would switch back to its default setting, in this case the Aux in.
Thanks for the continued support of this device.
Or
