WiiM Device: WiiM Ultra (Firmware 5.2.734250)
Network: Ethernet (hard-wired)
Speakers: Focal Shape Twin (active)
Subwoofer: B&K P12-300SB-PR
Sources: Samsung S95B (HDMI ARC), DLNA Streaming (hopefully)
My first post on the forum (RCA to balanced speakers - background noise problem) was about a noise problem with my new Wiim Ultra.
That situation was complicated by 2 factors- fault in one of my active speakers that was causing noise in that channel, plus the fact that those speakers (actually active studio monitors) only had XLR inputs, so an unbalanced-to-balanced connection was involved.
I now have new speakers. While the Focal Shape Twins are active studio monitor like my previous KRKs, these are (a) brand new; and (b) have RCA inputs so the system is a classic domestic unbalanced setup. I have also changed the physical arrangement so the Wiim, speakers, and sub are all on one wall with shorter cables. (the longest lead is a 5m shielded RCA to one speaker)
Problem: the noise issue is still there!
It's not as bad as it was before, but it is still the case that-
It would be very helpful to know if anyone else has experienced something similar, or are your Wiim units as silent as the grave when they are supposed to be?
- When there is no music playing there is a continuous mains frequency (50Hz) background buzz coming from both speakers. It's quiet, but I can hear it sitting over 4m away in my normal seating position, so it's not quiet enough to be something I can ignore.
Note I am pushing 70 myself and my hearing is nothing special. The noise would definitely be audible to anyone with moderately good hearing using these speakers in their designed role as nearfield monitors sitting maybe 1.5m away.
- With the RCA leads disconnected the speakers are silent
- With the speakers powered on but the Wiim turned off there is silence
- With Wiim and speakers powered up, as before there is an audible "stepping" sound overlaid on the mains hum if the volume setting is raised or lowered using the Wiim app. The same noise is audible when using the front panel volume knob, so I don't think this is related to RF breakthrough. It seems more like output filtering or isolation problems in the Wiim
