Hello! I just set up a new WiiM mini, connected my Anthem MRX 540 through optical, and have run into an issue: whenever I start playing an album, whether on streaming or from my NAS, the first 1-2 seconds are silent, so I miss that audio. After that point, the stream is perfect (no issues with gapless playback, etc.). It's like it takes the Anthem a second or two to realize there is a signal. When I tried using the analog out, it worked fine.
Do you all have any insight on whether this would be an issue on the Anthem or WiiM side, and any recommendations? Would trying a WiiM pro with coax help?
Thanks a ton!
Other than this issue, the WiiM is great so far!
Thanks a ton!
