Better than Airplay
D700
If you have given up on Airplay with Wiim (curse you Apple) or your device doesn't have it, here's best option I've found:
For those seeking:
  • Wiim/Apple Music Ecosystem integration
  • Apple Music navigation: view, select, play, pause from any Mac, iPhone, iPad, Watch
  • Lossless music up to 24/48
  • Automatic bit rate switching: 16/44.1, 24/44.1, 24/48
Hardware:
  • Apple 4K TV - Generation 3 (A2737, A2843)
  • Monoprice Blackbird HDMI Extractor - Optical Out to Wiim Device
  • Note: I don't have Wiim Ultra or Amp Pro but I'd assume you can skip the extractor since they have HDMI eArc input.
Notes:
  • You can run ATV without a display but you'll need one for initial setup.
  • To play music: Use "Control Center - Apple Music" remote option to select streams, stations, library music: play, pause music
  • Control Center Remote works from all Apple Devices including Apple Watch.
  • Unintuitive Apple Feature:
    • When you drag down Control Center on iOS, there's a grayed out side panel that shows Apple Music icon.
    • Select Apple Music icon, it presents list of Airplay devices then scroll down to bottom to see "other devices"
    • Select your ATV from Other Devices and you'll be controlling Apple Music natively on the ATV, not over airplay. (the magic sauce)
  • On ATV you'll need to:
    • Enable "Settings> Users & Accounts> Home Sharing" which requires pairing to Apple Music. Repeat for other Apple devices you wish to use to control ATV.
    • Set "Settings -> Apps -> Music -> Audio Quality -> Lossless Audio
    • Set the "Settings->General->Sleep After" setting far enough out that it doesn't go to sleep while you are futzing around in Apple Music or pause it for a phone call.
Advantages of the ATV4K (Gen 3) versus Airplay:
  • This provides reliable, automatic bit rate switching of uncompressed lossless 16/44.1, 24/44.1, 24/48. This feature was apparently added last year and only works on gen 3 versions of ATV. (like other iOS devices). Even Mac OS X Sequia does not do automatic bit rate switching.
  • No compression like with Airplay
  • I've found bump to lossless 24bit audio is the differentiator, much more so than the difference between 48/96/192 sample rates. Do I want high Rez?...of course! ... but with 24/48, lack of 96/192 isn't a deal breaker any longer, it sounds fantastic.
Would someone mind confirming ATV works like this directly with Wiim Ultra/Amp Pro without needing to extract the audio first?
I could see moving to ATV/Amp Pro to get native Apple Music control and super simple/great sound quality setup.
All that said, dang it Apple, why make us jump through hoops, just give us 24/192 Airplay option and call it a day.
Good luck!
For those seeking:
Hardware:
Notes:
Good luck!
The HDMI on Ultra is ARC - it won’t work directly from a device’s HDMI out.
Have you tried it?
Apple enabled bidirectional HDMI ARC support on ATV last year so wonder if that restriction applies.
For those seeking:
Hardware:
Notes:
Good luck!
But… isn’t that AirPlay? AirPlay enhanced when communicating with aTV?
