Can wiim do the following? High and low passing
alaios
So pick the most advanced wiim device and then help me understand if the below are possible.
Can i high pass my main speakers and relieve them from having to try to go too low?
Then can I high pass (yes high pass) my sub (sub out) as these are smallish and do not got really below 40Hz. I would like also to relieve them of having to try to play 30 or 20Hz.
Are such things possible with wiim ? If yes where I can read before buying the guides/tutorials
Regards,
Alex
I should have quoted only this part to make it perfectly clear. So, let's try again.
Yes, exactly. That's how it works.
When you enable the subwoofer output (available on WiiM Ultra, WiiM AMP Pro and WiiM Amp) you find a crossover frequency slider like so:
You can freely set the crossover frequency between mains and sub from 30 Hz to 250 Hz. No matter which value you choose, the result will always be both, a 4th order Linkwitz-Riley low pass for the sub and a matching 4th order LR high pass filter for the mains.
This is ideal if you have small main speakers or full range speakers. If set to e.g. 80 Hz, the your mains level will be down by 6 dB at 80 Hz. Below 80 Hz the level is reduced at a slope of 24 dB per octave.
Correct again. With no additional PEQ applied the sub will get all the frequencies below e.g. 80 Hz. More precisely, the sub level will be down by 6 dB at 80 Hz and higher frequcies are attenuated by 24 dB per octave.
When combined, the frequency response of mains and sub is perfectly flat again.
I understand that you not only want to relieve your main speakers from the low frequcies fed to the subwoofer. You also want to make sure your small sub doesn't have to cope with the lowest frequencies, which it cannot reproduce anyway, but just cause distortion. And yes, another high pass filter at 30 to 40 Hz would be the natural choice here.
WiiM PEQ cannot exactly do that, but it can do something that serves the same purpose. While PEQ filters cannot be of type "high pass", you can e.g. employ a low shelf filter like this:
The result is not a true high pass filter, but it will dramatically reduce the low frequcies fed into the subwoofer. If you want even more attenuation, just add one more low shelf filter, e.g. like this:
This will be as effective as a high pass filter
@Wiimer has shown an alternative approach in posting #5 using just peak filters. This will also work.
Is this more clear?
So what you say is that there is the PEQ filters and at the same time the crossover frequency. It is the crossover frequency that will high pass the main speakers and not the PEQ. So in the example above there are two "filters" running in parallel. The crossover and the PEQ that you drew here.
I guess both are applied in the digital domain so I can use the wiim ultra just as cheap dsp unit and feed it digital output to the preamp of my preference.
Yes and yes. :)
Yes. Multiple filters to handle multiple requests. You cannot say that they run in parallel. They are just all applied to the same digital data stream.
The WiiM Ultra has a good DSP but it's primarily a streaming pre-amp.
No. Not to a pre-amp. Only to a power amplifier, as else you will have issues controlling the subwoofer volume in sync with the main speakers.
Yes. Multiple filters to handle multiple requests. You cannot say that they run in parallel. They just all work on the same digital data.
No. Not to pre-amp. Only to the power amplifier, as else you will have issues controlling the subwoofer volume in sync with the main speakers.
Good to hear about the DSP.
Related to the pre-amp you are right. I should be using the wiim ultra for
1. source selection
2. Type of dsp device (all the discussion above)
3. volume control.
then I need to buy power amplifier for my main speakers. Mission accomplished
1. source selection
3. volume control.
No problem then. I had initially missed the term "preamp" and indeed you must be controlling the volume of mains and sub on the WiiM Ultra to keep the balance between them matched. A power amp is all you need.
Nowadays many small power amps do come with an additional volume control (mostly for desktop use). In this case you will have to keep this volume control always at the same level (e.g. fully clockwise), because again a volume control on the power amp won't control the subwoofer.
1. source selection
3. volume control.
he seems to have understood that since the beginning the approach of wiim is not with the use of dedicated dsp chip...
I am not sure I follow you here. What you say is that wiim ultra is not as capable as a dsp chip (like the minidsp) but with its filters you can have the job done somehow
I was just saying that no specific dedicated "dsp" chip... no judgment... (maybe an impact on the latency side with a non-specific chip?)
The Amlogic A113 (used in the newer WiiM products) is not a specialised DSP, but a quad-core CPU based on the ARM A53 architecture. It's not a standard smartphone SoC, though, it's been specifically designed to power audio appliances.
Amlogic does not provide a lot of public information, but it's obvious that this chip is not only capable of running the WiiM operating system. It really can do DSP work without an additional DSP. WiiM keep adding new features and so far the A113 has not become a bottleneck.
what is interesting is to see if the beta which seems to be in progress (?) for the mini is effective?
while the processor and more modest memory....
somes news?
