Realisticandcredibility
- Jul 25, 2024
Anyone test to change to a better power cord on the Ultra?
Define "better"?Anyone test to change to a better power cord on the Ultra?
Define "better"?
Apart from the aesthetic aspect there's absolutely 0 improvements that can be made to the sound of the Ultra itself by changing the power cord. If some of your other gear is sensitive to AC noise, you could benefit from better shielding, better cable management or just get rid of the poorly-designed gear
What power cord are you thinking of buying?Anyone test to change to a better power cord on the Ultra?
Are you going to re-wire your house to "better" mains cables?Anyone test to change to a better power cord on the Ultra?
Rob Watts from chord discovered how destructive RFI on the grid was for sound quality, when he tried a screened power cable - the result became clearly better , even If it shouldnt be the case because he had the power supply with regulators that makes this RFI much lower .Anyone test to change to a better power cord on the Ultra?
well well, fellow rock star how you been? Just simple shielded either rca or power cord would do the trick but don’t need to spend a fortune to on fancy cable.a much more obvious, abnormal, but exploitable point was described in the onlyoneme test thread...
surprising that he didn't react... this point...
You mean the Rfi that the powersupply in the Ultra is spreading back to the grid ? Two ferrite cores for the power cable will for sure make this better , and probably other switched mode power supplies would be technically better to.a much more obvious, abnormal, but exploitable point was described in the onlyoneme test thread...
a shame, you who asked about a specific point... this point...You mean the Rfi that the powersupply in the Ultra is spreading back to the grid ? Two ferrite cores for the power cable will for sure make this better , and probably other switched mode power supplies would be technically better to.
Im gonna try this on the Ultra and report back.
Good suggestion and maybe the best upgrade one can do regarding the power grid .Instead of buying an expensive power cable, I recommend to have an electrician install a dedicated power line with built-in surge protector from breaker box.
No it won't be... It will make 0 difference for the sound of the Ultra. It uses a modern SMPS which in itself would be a huge noise source if it hadn't been properly shielded and filtered at the output stage. It modulates the incoming AC power to a pulse signal at super high frequencies, basically nullifying any incoming noise.The sound will probably be a bit leaner and harder and in a very warm sounding system it might be beneficial .
Yes, and the sound might change because of that ( other components such as amplifiers and external dac might change their performance ) . Been there, done that 30 years ago. Its almost for free to try this.A ferrite block may help to prevent noise coming from the Ultra seeping through to the rest of the system though.
Interesting article but unless I'm missing something it doesn't mention ferrites on power cords at all just audio cables.Yes, and the sound might change because of that ( other components such as amplifiers and external dac might change their performance ) . Been there, done that 30 years ago. Its almost for free to try this.
This is a profound article :
