waldo
Or, you can easily buy one of the many inexpensive cables (some listed above) that actually do fit, instead of voiding your WiiM Pro warranty.
Pro plus came out with more clearance. Maybe new production pro's got the new chassis.According to this thread, I ordered the Mediabridge Ultra Series. When I plug in the coax, there are plenty of clearance around it. Maybe Wiim has opened up the clearance due to the complaints?
It is indeed an optical cable, when I wrote that it was pre my morning coffee and the word escaped me!You should have got an optical cable with the Amp too. See “what’s in box” in the manual https://wiim.attachments2.freshdesk.com/data/helpdesk/attachments/production/72072219138/original/WiiM Amp User Manual.pdf
What does your “something else” look like?
I do like WBC cables but for a short 4ft 75 Ohm digital cable there’s nothing wrong with Mediabridge a quality cable that will not deliver bits any worse than any other short cable.I recommend Worlds Best Cables from Amazon. Not the cheapest, but not expensive and excellent quality. Better than mediabeidge cables.
For what it's worth, I bought a cheap coax cable from Amazon that would be delivered the same day as my WiiM so that I could get up and running quickly. A couple of weeks later I decided to try something a little better made. I bought a slightly more expensive, but much better cable from Blue Jeans, and there was a rather large improvement in sound quality. Everything just sounded clearer for a lack of a better way to describe it. I even a/b'd with my fiancé and she agreed. It was a rather large change. We thought the old cable sounded great until I bought the new one. Sure, all the one's and zero's were likely getting there just the same, but there are variables like connector quality and impedance of the cable, and just because a manufacturer claims to meet the standard doesn't mean that they actually do.I do like WBC cables but for a short 4ft 75 Ohm digital cable there’s nothing wrong with Mediabridge a quality cable that will not deliver bits any worse than any other short cable.
Coax cables suitable for S/PDIF can in many cases still make good RCA cables for analog use.Note that the digital coax cable looks like an RCA cable, but they are not the same.
And vice versa!Coax cables suitable for S/PDIF can in many cases still make good RCA cables for analog use.
Yes! The reason for that is probably still simpl, the other way around: Coaxial cables do have desirable properties for transmission of low frequency analog signals (like music), which are somewhat, but rather loosely related to the requirements for HF transmission.And vice versa!
