Here is the link of my digital path, CD player -> WiiM Pro + -> Dac, I am pretty sure that the CD player outputs 16bit 44.1khz signal to the Wiim Pro + but the Dac shows the input signal is 24 bits 44.1khz when I set the max output of the coaxial of Wiim pro + to 24bits and it shows 16bits 44.1khz if I set the max output to 16bits. Does anyone know why it is and have experience of it? If so what is the cause of it? It is not a big issue but it is just annoying that every time I want to listen to CD, I have to manually change the max output.
