The future of affordable amplifiers: WiiM AMP Ultra review | Darko.Audio
Software first, hardware second.
His one bedroom duplex has a big hallway![]()
Software first, hardware second.darko.audio
What do you think about the review,,![]()
He obviously doesn't know how the sub/speaker sync works"The WiiM app’s Sub-Speakers Sync Test reported that the KEF sub sitting 50cm in front of the loudspeaker plane was running 2ms behind the Vivids. The app, therefore, set the loudspeaker delay to 2ms. Did I trust that result? Not until I’d confirmed it with the manual slider. I played a few cuts from Rhythm & Sound’s eponymous 2001 album and listened for the delay setting that had speakers and sub audibly ‘thwump’ into a single source. That happened at 2ms".
Enough for me to stop reading... Subjectivity at its best. Don't get me wrong, I do think there's much more than measurements into what make us consider a given piece of equipment. However, using your ears as goldstandard to adjust the delay of the speakers and subwoofer to 2ms is simply ridiculous.
Felt it was more of a review of WiiM's Roomfit and bass management tbh, but I tend to take most Youtube reviewers/ "influencers'" opinions with a pinch of salt. Entertaining enough read thoughWhat do you think about the review,,
Yep me to,Felt it was more of a review of WiiM's Roomfit and bass management tbh, but I tend to take most Youtube reviewers/ "influencers'" opinions with a pinch of salt. Entertaining enough read though
As mentioned in an earlier post anyone reading his review would think that the automatic sync for subwoofer and speakers works when the WiiM is not at the listening position.Felt it was more of a review of WiiM's Roomfit and bass management tbh, but I tend to take most Youtube reviewers/ "influencers'" opinions with a pinch of salt. Entertaining enough read though
I think the Darko reviews try to target things in basic layman's terms. He doesn't take too many deep dives into the technical side of things from what I have watched.More BS here. If only it did use the smartphone mic but we know it doesn't.
"Also dispensing with the second-guessing is the Home app’s options for subwoofer delay: manual or automatic. The Wiim Home app’s wizard plays test tones that are ‘read’ by the smartphone’s microphone and returned to the app for analysis."
Yeah, his past few WiiM reviews have had factual errors like that in them, and he seems to have an almost pathological aversion to mentioning Amazon Music support where I think WiiM are still the only streamers to offer that bit perfect via Alexa or the Amazon Music app.I think the Darko reviews try to target things in basic layman's terms. He doesn't take too many deep dives into the technical side of things from what I have watched.
Basic layman's terms are fine if they are still correct. False information is false information.I think the Darko reviews try to target things in basic layman's terms. He doesn't take too many deep dives into the technical side of things from what I have watched.
Exactly. I’ll give them a listen, and usually know within the first 10 seconds if they’ll be at least tolerable enough to go on. From there, I just wait to see if any issues or complaints are about anything I care about (same as when I’m researching anything else), all the while looking to see if they have an obvious bias or agenda (which is usually just bringing attention to themselves). After all that filtering, I still just take whatever they say with that quintessential grain of salt.Felt it was more of a review of WiiM's Roomfit and bass management tbh, but I tend to take most Youtube reviewers/ "influencers'" opinions with a pinch of salt. Entertaining enough read though
There's no guarantee that the result of the automatic sync is always wrong. It all depends on positioning of sub and speakers. It can work out by chance.As mentioned in an earlier post anyone reading his review would think that the automatic sync for subwoofer and speakers works when the WiiM is not at the listening position.
This is actually the least thing I would argue against. It's not the gold standard, of course. But since a) we know that automatic sync uses the wrong microphone, so is usually lacking and b) most users have no measuring equipment then what is the next best thing but just playing around with latency and listen?However, using your ears as goldstandard to adjust the delay of the speakers and subwoofer to 2ms is simply ridiculous.
