Headphone EQ setting in presets
uffe
Location
Sweden
Now, when Headphone EQ can be set in addition to input EQ, wouldn't it be logical if Headphone EQ setting can be specified in presets as well?
(I only use headphones with my Ultra)
Upvote 0
I think all you need to do is create a custom EQ similar to the headphone EQ and save it as a preset. After all, if you’re only using the headphone out, isn’t the headphone EQ unnecessary?
(I don’t mean to argue with your request, but I get the feeling that what you want to do is already possible.)
Yes, I have used the custom/input eq for my headphones as you describe. That's OK. I feel it is logical to manage the recently introduced headphone eq setting in a more flexible way, just like the custom/input EQ.
