Hooking up SMSL reclocker and SMSL SU-1 DAC. What output to use from reclock to SU-1?
cityshooter
I'm using the SMSL PO100 reclocker and the SMSL SU-1 in tandem. Do I use the USB to PO100, then ... what do i use between the PO100 and the SU-1? AND THEN. do I need to have a return into the WiiM? I've never done this before.
For those who watched the cheapaudioman video and believe this is of benefit over the Ultra’s DAC, I understand it’s usb out from the Ultra into usb in on the PO100 then whatever digital out out that has into the SU-1
Thanks. I don't know If I'll hear a difference. I'm going to get the DAC first. The sound from the Wiim is a bit mid heavy, even with the EQ set. I'm going Amazon, so if I notice ZERO difference, I'll return it.
The PO100 is not a reclocker, precisely speaking. Of course it's a non important semantic difference only.
