How can you tell which way the phone is orientated? That could be the top or the bottom.
The mic is in the front! THIS matters, not the rest…
I like many others I'm sure, will be taking their first steps into room correction using an iPhone,and the new Wiim app. My question is, do I manually set the frequency of the crossover and volume on my subwoofer on my 2.1 system , and then run room correction, or does the it work it out itself ? Very confused, many thanks
You set up the crossover frequency, the sub level and the required delay manually. Room correction doesn't tackle these settings.I like many others I'm sure, will be taking their first steps into room correction using an iPhone,and the new Wiim app. My question is, do I manually set the frequency of the crossover and volume on my subwoofer on my 2.1 system , and then run room correction, or does the it work it out itself ? Very confused, many thanks
WiiM may have great engineers, but they could use a little help on the Technical Writing / Artist side.Interestingly, that isn't the orientation featured in the WiiM Home iOS Room Correction FAQ, but rather
True. There are a couple of discrepancies in this regard. It is also written that it does not work with Subs. It works perfectly…Interestingly, that isn't the orientation featured in the WiiM Home iOS Room Correction FAQ, but rather
