Agreed. That's how the WiiM Amp works, too. But in any case the term "bypass the internal DAC" is not quite appropriate. The internal DAC will always be used for digital inputs. For analog inputs there's more that needed to be bypassed than just the DAC ...The issue is the analog input chain on an AVR. It typically goes like this.
Analog -> ADC -> DSP -> DAC -> Amp -> Speakers
Add a WiiM in front
WiiM DAC -> Analog -> ADC -> DSP -> DAC -> Amp -> Speakers
OR
WiiM -> Optical/Coax -> DSP -> DAC -> Amp -> Speakers
Even if your Pure Direct or whatever disables any DSP it can be converting from Analog to Digital and back to Analog if you use the WiiM's onboard DAC which normally you would want to do as it is usually better than the one in your AVR.
