Line-in to Coaxial on Pro Plus (Solved)
yannchris
Location
Brittany
I'm currently playing an analog source connected to the Line-In input of my Wiim Pro Plus.
Unfortunately, I get no sound from my active speakers connected via Coaxial.
What to do?
Kind regards,
Yann.
You are right, it's a turntable.
The line-in of the Wiim is connected to the tape-out of a vintage system, so the preamp is built in the amplifier.
So Wiim can distribute FM, Phono and Tape to the recievers.
What to do?
Kind regards,
Yann.
Are the audio outputs and audio inputs in the WiiM app set up properly?
Also, can you hear the test audio for the coaxial output resolution in the audio settings? If you can't hear the test audio, set it to match the input resolution of the active speaker.
