LS50 Wireless? Use a digital connection from the WiiM to them, don't go analog.which high end Audio RCA Cable from line out to KEF LS50 Wireless speakers would be the best recommendation?
My Budget is Limited to 300€!
They are streamers of their own. What do you want to connect to them. The don‘t have RCA inputs anyway, only 3.5mm aux in on the analogue side.which high end Audio RCA Cable from line out to KEF LS50 Wireless speakers would be the best recommendation?
I want to Connect WiiM Ultra line out with KEF LS 50 Wireless AUX Connection as Output, which are Both RCAs. The toslink opt out Connection is very flat After all EQ settings. I am using a Supra ZAC toslink Cable , the source is Qobuz, so high res.They are streamers of their own. What do you want to connect to them. The don‘t have RCA inputs anyway, only 3.5mm aux in on the analogue side.
I made it with Supra ZAC toslink Cable, but the Audio output was like I put socks over the speakers, although I modified my EQ settings, some members reported about analog Connection, which was better!LS50 Wireless? Use a digital connection from the WiiM to them, don't go analog.
-Ed
Which cables you use (brand, price) is irrelevant.I want to Connect WiiM Ultra line out with KEF LS 50 Wireless AUX Connection as Output, which are Both RCAs. The toslink opt out Connection is very flat After all EQ settings. I am using a Supra ZAC toslink Cable , the source is Qobuz, so high res.
The direct WIFI Connection to the Wifi Connection of KEF is much better!
Double-DACing must be the new-school substitute for tube distortion.Which cables you use (brand, price) is irrelevant.
If you connect the Ultra via analogue to your KEFs chances are high that the signal will be redigitized by the KEFs. That would render absolutely nothing, on the contrary. Either you use a digital connection or scrap the project all together. Just my 2 cents.
The Ethernet cable is actually optional, so you can get away with two cables (and accept a lower bandwidth of the inter-speaker connection).KEF calls them wireless but to do anything you at minimum need 3 wires (2x power and a patch cable to interconnect the speakers)![]()
Not necessarily. Some resampling algorithms sound reminiscent of chalk on blackboard. Pick your poison.Double-DACing must be the new-school substitute for tube distortion.
-Ed
Like rolling the wrong tube.Not necessarily. Some resampling algorithms sound reminiscent of chalk on blackboard. Pick your poison.
