LMS display & control on fire tv
castalla
Location
Comunidad Valenciana
Wiim mini - LMS Material skin plugin - LMS upnpbridge plugin - LMS-lite plugin - Silk browser on Fire TV.
This setup displays the now playing screen, plus alexa voice selection of favourites
Yes - gives voice control
I use it (when it doesn’t disconnect and I need to go hunting for the ngrok authentication details again) but it was describing the skill as a plug-in which I wanted clarified. Thanks.
I installed ngrok on a pi zero many moons ago - I used the original manual setup instructions (which were heavy going). Fortunately, it's worked ever since. Very occasionally I have to re-enable if the ip changes.
I played around with the full version but found it too command heavy for my brain. In truth, I really only use it to turn devices on/off and to switch between favourites.
I misclassified it as a plugin - sorry. There was originally a voice plugin which worked quite well but the developer ceased support.
