LMS Interface
Angelos58
Thanks to Brantome I'm trying LMS with Material Interface.
I set also the info Artist plugin, but in my interface I can't see information.
and ... is there a EQ with LMS?
How can I order the search Albums by date of release?
Thank
Thank
Are you using Qobuz in LMS? You can use EQ plugins in LMS but you can still use WiiM EQ.
Thank
If MAI is installed. In Material there is an (i) icon at top right. Tap that.
EQ as advised
Display order. At top of the page is an A/Z icon that will change sort order in various ways.
Screenshot shows both.
EQ as advised
Thank you. I icon works. But I can't see AZ icon in my Qobuz searching page and no Qobuz Eq
In Qobuz you get what your given sort order wise UNLESS you set up Online Music Library Integration to import the Qobuz data and merge it with local files. Then the sort options are available.
My earlier screenshot is a merged library - note the Q overlay on some albums.
You will find OMLI under Server / Settings
To get EQ in LMS you need to install additional plugins. I don’t use EQ at all so no advice from here.
I did it but no AZ icon and no HiRes label
If you are using PC I think you will find A/Z icon under the three horizontal dots on top row slightly to left of queue window. Near to Volare in your screenshot
The Hi-Res label option is a piece of text displayed in the Default gui.
The Q overlay has to be toggled on in OMLI settings.
Thank you I'm on a Mac and under three dots there isn't AZ.
Yes, it's right. But I haven't a music of mine. I only use Streaming service. How can I have AZ also searching in Qobuz or Tidal or ..?
If you integrate Qobuz into your non existent local library but browse as if you had a local library then you can sort as you wish.
Tidal should work in the same way and will combine
