Lossless "cd quality" radio stations
gasolin75
Active Member
I asked in another forum for suggestion for the ultimate free music to stream
Lossless
One suggested https://www.hiresaudio.online/cd-quality-internet-radio/
Problem is you have to manually search for stations on the app, you tried on you pc and wanted to include as a favorite or to a preset, to see if it's there
I would very much appriciate if there was an option where you can search thru stations that are lossless, basically cd quality
Why settle with mp 3 quality, less than youtube or even less than cd quality when you can have cd quality ?
Upvote 0
Android
Atm naim jazz say 16 bit and 44.lkhz when i used the link on the naim site
radio paradise shows played time, remaining time of the song, cover of the song or album it's from, album titel,song and artist, naim jazz doesn't do that, others might do it, it's just very nice to have that
And it show bit rate and sample rate atm JJ Cale Call Me The Breeze 857kbps/16 bit and 44.1khz
BUT they don have any jazz,radio channel, no electronic music or dance music or mabye im luck to find one from the 80's when i was young (yes the 80's is a long time ago) i wanna listen to that can be more interesting to listen to then playlist on tidal
Radio paradise is as good as it get's when you want free lossless streaming that works with a wiim ultra (if it's as easy to use on other streamers i don't know), it just don't have all the genres i like but for 95% of the time it's good and lossless
Did you save the playlist as
Radio Stations.m3u
and then import it using the new import option?
There are two playlist files, one m3u and the other m3u8. It was the former I managed to download and import on Android.
I didn't see the m3u8 file. Maybe only the m3u file imports correctly
I downloaded from this page
I now have it, i had to download it from my pc and sendt it top my phone thru bt
I just only have 178 stations starting with nr 357 Big Bang Radio as nr 1 in custom order
Some stations are 320-mp3 and some are 128 acc i don't see those stations being close to lossless
cd quality is harder to find than 320-mp3 and 128 acc, that's why i asked for an easy way of finding and adding lossless to streaming ,radio
Must admit im not interested in anything then 100% lossless like radio paradise, since since medium or high mp3 quality, really is just normal high quality, not close to lossless, which is harder to find
This information from radio paradise is als perfect (in case you need to find the record, this from my phone but wiim ultra is the same information above the bac,pause,forward buttons)
