thatdoodle
- Feb 21, 2025
Hello,
At max volume out of my pro plus using RCA into a pair of Fosi V3 monos I'm not getting particularly loud output. I've tried hooking up a multimeter to each of the output channels and playing some test tones between 50hz-1000hz and am reading roughly 0.6v-0.1v respectively. The test tones are 0dB, and I've tried using both Spotify from my partners phone and YouTube music from mine.
I've checked my settings and the WiiM is at 2vrms in the settings, volume limit is set to 100% and volume of the unit was set to 100% while testing. I'm not sure what else could be causing the output to be so low, as the ASR review was showing almost exactly 2vrms out using a 1khz test tone.
Any suggestions would be greatly appreciated.
