Why do you leave it open? Does it heat up?I purchased my Wiim Pro Plus a month ago on Amazon.it, it is version 3, to my ears I heard no differences by changing the original power supply with one from the iPhone.
I feel better if I leave the Wiim box without the lid with the open side facing up.
I copied as you described and pasted into the browser, it always takes me to the forum postJust call
https://<your_wiim_ip>/httpapi.asp?command=getStatusEx
in the web browser, an look for "PCB_version" section.
No, because it is heard better on high frequenciesWhy do you leave it open? Does it heat up?
Did you replace <your_wiim_ip> with the IP of your WiiM?I copied as you described and pasted into the browser, it always takes me to the forum post
Type https://192.168.1.131/httpapi.asp?command=getStatusEx into your browser, replacing the IP address with the IP of your WiiM deviceI copied as you described and pasted into the browser, it always takes me to the forum post
I deleted it....to rude. But you proved once more: The net does not forgiveCa’ canny![]()
So I suspect you have a "normal" Pro Plus revision as the one I'm testing currently is probably not yet available on the market.On the PCB it says version 3 on the browser it says version 2
Isn't it worth buying another Allo Nirvana power supply or linear power supply?So I suspect you have a "normal" Pro Plus revision as the one I'm testing currently is probably not yet available on the market.
Issues mentioned here do not affect your WiiM.
Because of the Pro Plus alone? IMHO no.Isn't it worth buying another Allo Nirvana power supply or linear power supply?
Thank youBecause of the Pro Plus alone? IMHO no.
yes, if correctly placed on the cabinet it is the PCB at the top@onlyoneme yes you are right there are 2 pcb inside. It is possible that the api returns the general hardware version.
@nerone is your photo shows the top pcb?
