Occasional crackling using chromcast
Bozzz
Valued Contributor
When I stream to my WiiM pro plus using the Qobuz app I’m getting an occasional crackling sound through my speakers. When I use the WiiM app to control Qobuz and play the same song….no crackling at all. My WiiM is connected with Ethernet so not sure what the sound could be. Any ideas?
Try adjusting that sample rate switch latency on the audio output page of the app, or maybe try lowering the line out level on that page. There is a note there that too high a output can cause distortion.
Ok cool thanks. Will give it a try.
