Might you need to do the same for the AIFF and ALAC settings there too to cover all the bases?Are they .M4A files?
If so change this File Type from Native to Disabled
Server / File Types
EDIT
Make sure you "Save Settings" at bottom after changing. No server restart required.
The Bridge does transcodeWere you transcoding the ALAC files using the UPNPBridge plugin? WiiM should be able to play ALAC files natively
I wouldn’t fiddle further unless a problem arisesMight you need to do the same for the AIFF and ALAC settings there too to cover all the bases?
Sadly no... I'm annoyed I didn't bookmark it at the time! It specifically talked about changing the file types to disable the ALAC settings.
It’s the AAC setting for M-PEG4 are you sure used did that and then “Save Settings”?Thanks again
I cannot find "advanced" only "basic" setting, but did find "file format conversion" there.
Changed AAC to disabled, and saved it.
Playback timer still resets every 1second.
Send a screenshot of the File Types settings
I was just going to say we need to look at the logs.Might it need ffmpeg and/or Lame installed? Wouldn't the LMS logs show errors which might suggest this?
In post 114 it appears @AlanB has done that?When I changed the Apple Lossless section to Disabled they worked for me.
