Pops and clicks when changing tracks on USB
g3rain1
The ultra is generating pops and clicks sometimes when I change the track, it could be a sample rate thing. I have the fade in fade out effects turned on which says it should eliminate that, how it doesn't seem to. I'm connected over USB.
Hi @g3rain1
My Ultra is connected via USB Out to my external DAC. No pop and clicks changing tracks. I listen to albums, not playlists.
I have fade in / fade out off.
Yeah, it doesn't seem to happen within an album. But when I change to something else it does.
Leans towards it being a sample rate changing thing.
Well, actually it's the dac doing that on sample rate changes, not the ultra per se.
The wiim fade in/out attempts to mitigate this issue, but doesn't guarantee it.
Guess you need to wait for fixed sample rate over usb (assuming it's coming) to prevent this with your dac.
I have clicks when using coaxial connection to amp. It is pretty annoying, it can happens all the time, every hour
With optical it works good, so I am using optical.
Does anybody know what is the issue here?
Are you using USB as a source?
Nope, i am using tidal.
It happens when listening music using coaxial connection.
If I am using optical instead of coaxial everything works perfect.
That's a completely different topic then, better handled in a separate thread.
But as a side note, I don't understand why you mean by using Tidal using a coaxial connection. Are you using an external DAC connected through coaxial out? If the problem is with Tidal only?
You're best of starting your own thread with all the details.
I am using Audiolab 7000a connected via coaxial to wiim ultra and to tv through hdmi. It happens everywhere, when I am using hdmi when watching tv and when streaming music
The Audiolab might not just cope with the coaxial output resolution you set or the coax cable isn't up to it.
I used max possible resolution 192/24.
looks like audiolab is capable of this resolution via coaxial connection. Do you think issue can be on cable side ?
Is coaxial cable not capable of it?
The WiiM Ultra is surely capable of it, but that doesn't mean your cable and your DAC are.
Unfortunately is this issue still prevalent. I've tried different DACs, lastly a Topping E70 Velvet connected via USB Out from Wiim Ultra.
Everything is set to fixed output resolution. Still clicks/statics when changing songs via inputs through Ethernet, Optical and Line In. Definitely a Wiim Ultra problem here that seem difficult or impossible to fix. I had to go back to using Optical Out and set a latency switch to approx. 1100ms. That works fine but I will definitely replace the Ultra in the not too distant future.
