Tidal not showing wiim devices
xtreme
About a week ago when I play a song when I go to select my device it just shows my phone. I have 2 pro plus. I have tried reinstalling rebooting and nothing works. I have a JBL portable streamer and it will see that. The only way I can stream thru wiim is by using the wiim app
Welcome.
Have you tried removing the power from the wiims for a minute or so?
Also worth trying rebooting the router.
Is that on iOS or on Android?
Can you also test the Tidal app for MacOS or Windows at least temporarily the see if it makes a difference?
