Pro Plus WiiM Lite Smart Speaker Pair
s634life
I’m trying to connect everything together with the Apple TV and both of the Smart Speaker with Pro Plus .. Apple music
What is the correct way connecting everything together ?
Pro Plus
If you mean WiiM Sound Lite speakers, then I'd guess you'd need to connect your Apple TV over hdmi into your TV, then take an optical out from the tv into the Pro Plus. You'd need to link/group the Pro Plus with the two WiiM Sound Lite speakers, assigning one of the latter as the left channel and the other as the right.
You may experience some latency or lip sync issues in such a grouped setup, so you'll have to rely on controls in the TV or Apple TV for that.
Edit: see https://forum.wiimhome.com/threads/...ra-hifi-speakers-x2-wiim-sound-speakers.9485/
on Amazon is call
WiiM Sound Lite Smart Speaker​
After hours yesterday was able make it work through Wi-Fi no cable or anything…
On the iPhone, just open Apple Music and then pro plus finally hear both speaker working together as pair …
with Apple TV just airplay to pro plus..
My only problem is randomly I do lose sound…
