Pro plus with power amp
Set the Wiim line out voltage to 1V max. This Technics has a sensitivity of 1V.
And don't forget to turn off the fixed volume and turn down the volume so that the signal to your amplifier isn't too strong.
I think you'll be pleased.
This could actually be quite important, or at least another variable.
Like most things in audio, sound stage is more tricky a topic than one might think. As long as we are just talking left/right localisation things are fairly straight. There are mainly (but not exclusively) two mechanisms involved, interaural level difference (most relevant above 1 kHz) and interaural time difference (most relevant below 1 kHz).
When we audiophiles talk about "sound stage" we don't just think left/centre/right, though. We are sure that we can hear the depth of the sound stage in various layers, with instruments in front of and behind the speakers. We even are convinced that only with the right DAC/Amp/cable riser/speaker placement the height of the sound stage will just fall in place with good recordings. And of course, this isn't entirely wrong. :)
It's just that for sound directly in front of us or behind us, above us or below us (should that happen) and everywhere in between always has the same level and zero time difference in the left and right channel. How can we hear a difference in sound stage height if both speakers are playing exactly the same signal? Stereo is of no help here! Same for the depth of the sound stage. If one instruments sounds further away from you than the other but both are directly in front of you, this has nothing to do with stereo at all.
So, what's happening then? Our hearing is evaluating additional clues. Most prominently, the shape of our auricles and the shape of our head come into play. Our hearing does in fact have a different "frequency response" (or more formally: transfer function) for sound coming from different directions. This is most important for front/back and above/below localisation of sound events, but it also plays a (somewhat subordinate) role for left/right localisation (think: sound stage extension ...).
For spacial hearing our brain tries to gather as many clues as possible, filter out conflicting information and create the most likely hearing experience for us. This is not trouble free. The more contradicting the different clues are, the more exhausting the listening experience can be. Regarding the depth of the sound stage, clues are even more vague. Sound sources further away from us are usually lower in level and higher frequencies are tamed more than lower frequencies. The next time you are in a real concert hall, close your eyes and try to find out how good our hearing really is at telling the distance to a sound source. Spoiler: Not very good at all ...
What all these additional mechanisms have in common is that they all rely on things that we had to learn! It's not pure acoustics leading the way. If you never heard a trumpet in your whole life, how would you know how different it sounds played in front of you or behind you? Of course, we are learning from experience and can extrapolate from all the sound events we have heard before. There are other even more obscure things our brain does to help us perceive an unambiguous illusion of sound around us. It's also a matter of concentration. I even heard that newer studies found a new additional influence on the so called cocktail party effect (in a group of many speakers we can filter out everything but the one we want to listen to). It appears that our brains even takes into account the direction we are looking. And I have left out may other factors like the influence of reverb or echos.
Why this long story, then?
Localisation of sound events is not just about phase and level. It's not even just about stereo. Many things come into play, it's a real mess. Even slight variations in certain frequency ranges can change our perception of spacial hearing, masking effects can have a positive or negative influence. Often we just need to take away few factors irritating our brains like certain characteristics of the listening room (while taking away reflections completely is not a good idea). Room correction and subwoofers can be really helpful here, but nobody said this is easy. You didn't like the outcome of your previous RC run, but there are lots of things you could change and try again (target curve, frequency range, max. gain and max. Q for correction). The most pleasing crossover frequency, delay and level for your subwoofer (to be detirminded before running RC) can all have an influence. An influence that is much, much more important than the difference between any two decent amplifiers.
Remember, it's all just really an illusion (which is not a bad thing).
Edit, for reference and further reading:
Thank you for a very interesting and erudite reply. Unfortunately I am not very informed about the variable parameters of RC and how to access and set them. I suspect it would be very frustrating for you to try and beat them into me by remote control!
For the speakers this is true. For the rest of the signal chain it is not possible and really don't matter. Any filtering or EQ will change the phase. That how it works.
Our ears are not sensitive to phase, only to frequency and amplitude.
If that notion makes you happy, wonderful, but no, precise soundstage cues is all about phase preservation.
Phase coherency and timing between multiple signals (2 in stereo) is the key for a good soundstage, as I described before.
Phase preservation in the individual signal paths is not that important as long as all channels have the same.
Individual channel EQ as now available in WiiM may actually break that?
IMG_1088.jpegThanks for the reply. I have the original WiimAmp. I love it. Except the soundstage doesn't extend beyond my speakers, which refuse to fade. This could very well be placement, but I think it might be a limitation of the WiimAmp.
Perhaps the current it has learned to produce is not powerful enough.
Another very important point in building a scene is power supply. Wiim is very economical on it. For my wiim pro plus, I replaced the standard power supply with a full-fledged one. The sound has changed a lot, and first of all, it is the staging of the scene 👍
I'd still like to know what the intended meaning is.
I don't know English very well)
I wanted to say that the power supply is of great importance for this streamer. The kit comes with a pulse and low quality. If you put a full-fledged linear one, as in my example, the sound will improve a lot.
And why is that? There are no technically reasons for that.
Power supply in acoustics is very important, so they put air conditioners and surge protectors. The switching power supply is not capable of producing a good clean current.
In Russia, many wiim owners change power supplies and all receive a significant increase in quality.
In my wiim tract, the cheapest and weakest link, but after replacing the power supply, I have no quality issues.
To note: Some are after 3rd party linear power supplies… the reality is that digital components (streamers/dacs/Class-D-amps) may suffer with those as they may lack appropriate RF filters, which a competent switching power supply should have.
