I have a WiiM Pro Plus, which is connected to the conventional stereo system via line-out (analog). Now I also have bought a WiiM Mini for built up a little multiroom system, which is connected to a JBL Flip via Bluetooth Out. The WiiM Pro Plus is the main device. Both WiiMs are to be linked for multiroom.
The problem is now that when the divices are linking, the Bluetooth signal to the WiiM Mini is chopped off.
If I use only the Mini for bluetooth out, without linking, the signal is clear.
If I switch the linking, that the WiiM Mini is the main device and the WiiM Pro Plus is the second device, the signal is clear.
I have already tested the second Mini, as I thought there was an error at the beginning. But the Problem is still the same.
I want to use the WiiM Pro Plus as main device. So changing devices is not my solution. I tested also another Bluetooth box. Problem is still the same.
Is there a solution for this problem?
Thanks a lot in advance.
