Remote
sNc
The remote is not always responsive. When not using the remote for a longer time, when trying to change the volume, or when trying to turn off the unit, I have to click multiple times to get any response. Do you have it like that too? Is this some kind of standby mode?
I haven't noticed that with my six remote controls. Have you checked the battery level in the WiiM Home app?
Version 41, Battery level: Normal
This only happens until first response. Then it works smoothly and without delays
I have noticed when the batteries are getting low, the remote control symbol in the device tab either comes and goes momentarily, whether that means it is losing its Bluetooth pairing, and occasionally the symbol is missing altogether.
This is a sign that I need to replace the batteries, and re pair it with the device.
I think I see the same. I don't use the remote often but when I do it never responds the first time I press a button.
