Request: Simultaneous output options
MrSoul4470
Active member
Location
Regensburg, Germany
Hello WiiM-Team, I would absolutely appreciate the option to select more than one output at the same time. In my case I would like to output Coaxial to my DAC and optical to my RTA. Other maybe want to output digital to their DAC and analog to some Peak Level Meter or so. Restricting output options to always just one option reduces versabilty. Unless there is a technical reason for it I hope multiple options at the same time can be made available in the future. I imagine there could be check boxes in the app to select all outputs that should be active. And since optical and coaxial is basically the same signal anyway, this shouldn't be a big problem. Thanks!
Upvote 12
We need this option to unlock all output. I have two DAC's for headphones amps and one amp for speaker. Avoid switching for every time save time and make life easier. Wiim, implement it please.
BTW, I don't see it on official roadmap for PRO and PRO Plus products.
This has been asked for many times in the past, and the most optimistic response has been that WiiM engineers might consider it if the hardware supports it, but no response has been forthcoming after that. It wouldn’t appear on the roadmap until they had investigated it, discovered they could do it and had the development scheduled for some time in the future. Its absence from the roadmap could indicate it’s not feasible.
Yes !!!!!!!!!!!!!!!!!!!!!!!!! I agree with you in 100% !!!!!!! This ONE ONLY active OUTput is STUPID AND NOT USEFULL . !!!!!!!!!!!!! Tine consuming setup option for NOTHING !!!!!!!!!!!! Stupid !!!!!!!!!
I believe there is no point to this, specially when this request is clarified under WiiM pro & Pro Plus. We're talking here about dedicated streamers which are part of an audio chain, not the all-my-expected-solutions-in-life-device. Align expectations with what you are really purchasing, as well as some common sense.
I requested that feature as well, so I can feed my primary and secondary (patio) setup simultaneously. However, I ended up using a Topping E70V DAC with my Ultra, and the Topping has simultaneous balanced and RCA outputs, which solved the problem.
If it affects sound quality I hope they don’t do it . It is better to pay 80$
I can't see affecting quality, most my old amps have 2 tape loops, making at least 2 copies of the signal and it doesn't seem to affect quality.
Given the absence of the humble cassette in modern equipment, the circuit may not be designed to support signal duplication though.
I have to say I would need this feature also. This way the signal could be fed to a PC with LEDFX installed, in order to control LED lights in sync with the music.
This feature has been requested since the early days of their first product. If this possible, it would have been added years ago.
Yeah, I think so too, but at least such messages will maybe result in new products with multi-out option included ;)
I thought that it was all part of their roadmap, That product I would buy, however what is it going to be called? The ultra-ultra or superduper?:)
Ultra plus, if car naming is anything to go by :P
