Room Correction -> Audio Check/Natural Sound - no sound audible
Abstracted
Android 16 phone
#1 Top Concern: Room Correction -> Audio Check/Natural Sound - no sound audible.
Optical in, Speaker out works perfectly.
Audio track stored on phone plays perfectly through speaker out.
But, Browse -> Amazon Music -> triangle play button only shows moving waveform -> then stops and turns into triangle -> then goes back to optical in.
I've used room correction perfectly in the past, but now I'm getting this issue. Nothing has changed on my end. I use optical in exclusively.
You know what we're going to say...
Pull the power plug for 30 seconds and try again.
Raise a ticket to wiim from the app, More, Feedback..
Android 16 phone
Hi Abstracted,
Please submit a feedback ticket from the WiiM Home App so we can troubleshoot this immediately. Thank you for your continued patience and support!
Normally there would not be a triangle button there. Is the input set to Optical and you pressed the Optical playback button?
Or have you simply omitted an explanation?
