1. No, because then there is also a reduction at the rest of the range, and I’m not looking to reduce at 60Hz, 50Hz, 35Hz, etc. Generally, it is best to have the room correction apply a gain reduction in one spot that attempt to raise gain in multiple places.
2. I don’t think that is the optimal use of the room correction. You need to get the total system as close to optimal as possible before applying room correction. You don’t want room correction having to apply massive (+/- 6+ dB) corrections, as the bigger the adjustments, the higher the likelihood of phase and distortion issues. You want room correction to do as little work as possible.
I also have a rather annoying null around 180Hz and I need to focus the room correction on that region of the spectrum to cut it down.
-Ed
Well, up to you…
