Roon is performing a Sample Rate Conversion to 44.1
BillA
Roon is performing a Sample Rate Conversion to 44.1 when playing any HiRes files to the analog output. Same behavior from my music server or Tidal streaming. If I switch to coax or optical output the HiRes files play bit perfect.
I have the latest firmware, EQ set to off, and volume set to maximum. This sort of behavior is not supposed to happen with a Roon Ready Device.
I don't have that problem. I used Room to play a 96/24 local file to my Pro Plus (Room ready) with analog out and there was no rate conversion. My screen looks like your 2nd example, with the exception of analog out.
Edit: Just tried Qobuz 192/24, still no re-sampling. No Tidal.
Maybe there is a difference between the Pro and the Pro Plus.
