Sample frequency error when using WiiM Ultra with Eversolo DAC Z8 via USB
Math You
I've got a weird bug with the display on my eversolo dac z8. Whenever I first turn on my dac, amp and wiim, if it's connected by usb the display on my eversolo will always show 768kHz, no matter which track I play. The only way to clear it, and show the correct sample frequency is to play a track from the presets on the wiim ultra. If instead I play a track using Tidal connect, it doesn't change from that 768kHz sample rate. Obviously this is a display bug, as there is no 768kHz content on Tidal. And I've never streamed anything above 24/192. However, using coax doesn't have this issue, it displays correctly and immediately switches to the correct sample frequency. Whether I'm using tidal connect or the wiim app.
You will likely get more responses on Zidoo's forums (Zidoo owns Eversolo and Luxsin).
-Ed
