hoohoohoo
Senior Member
- Mar 19, 2024
For anyone reading in the future and considering the 4G/5G router option, this should work for you with either a physical SIM or an eSIM.You will need another smartphone to control the device with the WiiM app.
Use one phone as a hotspot router and control the WiiM with the other.
If you don't have more than two smartphone or tablet, as @hoohoohoo said, a mobile router (or home router) is a good idea.
# The problem with using a mobile router is that you may need to put the SIM card back into your phone when you leave the house.
