SMSL SU-1 DAC with Ultra?
Appears it is not just me - CheapAudioMan tells about clock issue in Ultra limiting its potential and uses an SMSL PO100 to reclock the output. by using USB out to avoid the Ultra clock, and using external DAC is improved sound. The XMOS chip in the PO100 is the same as the SU-1 the XMOS XU316
Too bad by using USB out, the Subwoofer out will not work
So, he basically says that his DAC cannot cope with the amount of jitter on the Ultra's optical output. That same amount of jitter, which has been objectively measured to be very low (even if the SMSL PO100 Pro has even somewhat lower jitter, indeed)?
He also assumes (no proof given) that the SMSL SU-1 is suffering from the same PLL deficiencies, so buying two SMSL boxes is always better than buying just one?
Interesting. :)
Testing as I type: SU-1 with the PO100 pro in front. Ultra to PO100 connected and powered via USB and the PO100 to the SU-1 via an optical cable. Had to connect my sub to one the modded Fosi ZA3 instead of the Ultra, I think that that is by design due to internal routing. Firmware updated the SMSL devices due to some popping sound when loading/playing the next song (Tidal). This seems to be solved, still testing.
Sound: first impression that I hear a tad more details and I’m experiencing a nicer stereo image. I think you could say that I’m a bit more into the music… I consider this an upgrade in my setup!
Ps: I will take out the PO100 Pro and test again, to see if that makes a noticeable difference.
How did u update the firmware? Can't find it.
The more equipment the better?
Each conversation will just add more noise and distortion. But maybe that is what makes it sound better?
Has anyone tried the SMSL SU-1 DAC with the Ultra and if so, what were your thoughts? Im loving my Ultra so far, but I am curious to how much more it could be improved with the addition of a relatively cost effective external DAC.
Yes I have it connected to my Wiim Utra. Its a huge improvement compared to the internal DAC. I am using QED performance graphite digital optical cable and the Audioquest Golden Gate rca cables. Sounds more open, dynamic great treble, mid an bass. For that 69€ a great investment.
Doesn't really matter which fancy optical cable you're using as it has been recommended many times to connect external DAC's over USB, allowing the DAC to rely on its built-in clock circuit.
+ the bass AND mid AND treble sound more dynamic? You couldn't be any more specific? :)
I have received my smsl su-1 dac connected via coaxial input and a ifi P2 power supply via the USB port and i am very impressed by the listening that i find smoother and more opened than the internal dac of lmy wiim Ultra which already quiet good .
Is the power supply required? Or would it work by being powered via USB?
1) Including the Cables, it is MUCH more than a 69€ a investment.
2) Since you are having to disassemble/reassemble gear with no opportunity for Volume Matching, it is very likely that your "Improved Dynamics" are simply a small dB difference in the overall Volume level.
By using USB, the subwoofer control don't work. Hope @WiiM Support can update this feature in the next firmware update.
Been using Wiim Ultra with the internal DAC for a week. Today I switch back to SU-1 , and I am convince that SU-1 sounds better. Its just sound so much musical to me. Can't wait for the USB with Subwoofer update for the Wiim Ultra
