steadyshot
- Mar 14, 2023
Another free tweak . Run it at very low volume for 2 hours
+1 agree with this as well. but in my case my active speakers don't have coax in, and WiiM pro doesn't have USB-out, so it's the best option overall. i have experimented with Wiim Pro > coax > S/PDIF ipurifier > toslink > speakers vs toslink the whole chain (since i recieved my oyaide DST-75R V2 snake oil special cable!!If you employ a good optical cable you get both total galvanic isolation and low jitter and good bandwidth.Even if 24/192 would not work for my dac I wouldn’t care since the difference from 24/96 is trivial .The cable itself does not radiate to the equipment and other nearby cables and also is immune itself from other nearby emi/rfi that also can transfer to the dac .
So in my case I would not upgrade anything else. I found the sweet spot for me in my current setup.
Many choose to ignore the complexities of engineering sound reproduction devices because they have been commoditized in our society to a certain degree...and also, many forget that science often progresses by choosing a direction that was previously thought to be "wrong" and that dogmatic thinking is not scientific. what IS scientific is understanding the limitations of the methods at our disposal, and having an unbiased view when it comes to hypothesis testing. As george bernard shaw said “All great truths begin as blasphemies.”
a famous example in audio is Naim and their complete 180 on power cables. they used to be against the whole thing, and now they have their own line of them. you could call this shameless money grabbing...
but idk - the market would weed out this type of thing over time - it's not a sustainable business model to try and "fleece" your customers repeatedly over a long period of time. eventually people will catch on
I'm familiar with some of the tests mentioned in the links above. I particularly remember the stereophile one about amps quite clearly. If you read about the work they did - there are actually a lot of nuances in how you use tools like A/B testing to get to the "truth" in this case. Like in all of science. Some of the excerpts are quite eye-opening. Well worth a read. I'm familiar with some of the tests mentioned in the links above. I remember the sterophile one about amps quite clearly. If you read about the work they did - there are actually a lot of nuances in how you use tools like A/B testing to get to the "truth" in this case. Like in all of science. Some of the excerpts from the letters are quite eye-opening. Well worth a read. https://www.stereophile.com/features/113/index.html there were differences that were reproducible in a subset of the listeners. and many of the letters express very nuanced arguments.
Similarly in the goldensound video - he doesn't entirely dismiss the place that measurements have in the hobby - but the key is his understanding of the limitations of the tools we have.you have to listen to what he says, though - its not good enough to click away because you disagree with the title and thumbnail.
I actually think there is a lot more to the nebulous concept of 'SQ' than what we can measure. So I guess I disagree with @onlyoneme as well. I believe trained active listeners would be able to reliably hear differences between DACs and amps even in anechoic chambers, given enough time to get accustomed to the sound and being able to choose what songs/audio clips to A/B with (but not the sequence)....
I'm with @Matterhorn on this one. if you've actually spent time listening to different components like DACs in the same setup then differences are not even subtle in many cases. (i will caveat this by saying that if measurements are complete, and two components measure similarly, then they do also tend to sound similar) i'll try and get into these ideas more in my next snake oil updatefor now i'm just tryin to keep the peace and trying my best to encourage people to understand that hearing is a complex topic and that there is a lot we don't know about it
at the moment since i moved, i have a compact system because my listening room is small and i've optimised my setup for near-field listening... i have a WiiM pro>coax(Oyaide DST-75R V2)>ifi S/PDIF iPurifier>toslink (ludic orpheus optical)>vanatoo transparent zero+ > LFE out (QED reference 40 sub cable) > ruark rs2 sub.What is your system @bowsandarrows ?
Yeah... just get one!Sorry for the off-topic.
This is an amplifier from a company called "Ause" in Japan. (WATERFALL Power 502L)
WATERFALL Power 502L | 逢瀬
2021/10/13 サイズ表記の修正、サイズ参考写真をアップステレオパワーアンプ / 廉価モデル定価23万円+税(税込 253000円)WATERFALL Power 500と同等の性能デザインWATERFALL Power 500で採用した内容と同等のnCore+独自前段回路を搭載しています。上記製品と同等のクオリティを大幅に廉価に実現するのが目標の製品となります。また同じnCoreでもIntegratedで採用されている電源一体型のMause-audio.com
This is a power amplifier powered by a Hypex NC500, what do you think of the validity of what is described on this website?
The price is 23JPY(+10%TAX)/1,500USD.
Do you think it's worth the price?
Thank you.![]()
You're better off getting one of the many nCoreX ones around for similar prices or even cheaper (I'm very happy with my Apollon NCx500 personally). Provides they ship to .jp of course...Sorry for the off-topic.
The price is 230,000JPY(+10%TAX)/1,500USD.
Thank you.![]()
Thank you.![]()
Ah I see. Check ASR maybe for measurements and discussions of ncore ?@bherren, @waldo, and @Mr Ee,
Thanks for the helpful suggestions.
Sorry, I should have clarified the intent of the question. What I want to know is not what this amp sounds like. This is about the description of the amplifier written here.
The web page reads:
"Equipped with an original countermeasure circuit that corrects the imperfections of nCore"
I wanted to hear from people who are familiar with nCore on this.
But this question was too out of place. Sorry.
Dont pay attention to scientific audiophile in this case .ok, so now that the dust has settled a bit, thought i'd pop in with an update... please don't shoot me, it's not a snake oil update(one of those is coming very soon, and i promise to anyone who cares it's gonna be a good one!
more of just an expansion on stuff that keeps coming up in other threads but i don't wanna pollute them with my blasphemous ideas!
to those that are clearly in one church OR other (most people on these forums seem to be measurementphiles), please look away, go "enjoy the music" or whatever you need to do to keep calm before reading this!
(mods please don't ban me and @ WiiM team - the offer to shut me up with free prototype mini v2 or ultra is still on the table)
anyways, been catching up on scientific audiophile's youtube content (will refer to him as S|A from now on - very balanced and quite funny) and he's pointing out an issue that comes up a lot. many people on here seem to completely disregard my point when i refer to the "limitations of measurements" (or how we apply them).
in his videos on the WiiM amp and the Fosi audio za3 + v3 - S|A points out important measurements that many reviewers almost never perform (erin's audio corner does some like the pink noise test on amps) and the ways that manufacturers can "game the system" (does anyone remember the VW fiasco?!!) by making sure that the products test well under "standard ideal testing conditions" that they know the popular reviewers are going to use. (check out his short video on the za3 if you want to see a great example)
for example many of these new amps can easily play a 1 KHz test tone at the rated SPL through the speakers as mentioned on the spec sheet, but when a complex signal is used like pink noise (or multitone tests, or actual music) then they are NOT able to meet the specs they claim. obviously this affects every manufacturer to some degree or another - but it's much more rampant in the lower end class D amps than it is in the old-school class A or class A/B ones for example. this is what andrew robinson meant when he says "the problem with measurements is that they tend to show you the best WORST-case scenario" (and sometimes only that) in his "head to head" video of the WiiM amp vs onkyo AVR from @D1N0 's interesting thread...
the reason i need to point this out is because issues such as this would probably be quite apparent if you listened to an amp like this closely enough in a practical and realistc listening environment! you would maybe notice the lack of dynamics at medium listening levels, and obviously the lack of volume when you try to crank it up... i mean shocking, right?!you mean you actually need to listend to an audio reproduction device to evaluate it? haha!!
(as a side note - iDO NOT
recommend listening to music loud (>75dB) for periods longer than a few minutes at a time WITH BREAKS!! acoustic damage that causes hearing loss is real, people - and i don't hear enough people talking about this tbh
. it's worth pointing out much of these specific issues highlighted here might not apply to playing music at "normal" listening levels <70dB)
but anyways maybe these ideas can demonstrate the value of combining both listening and measurements when evaluating equipment, and trying to improve the application of both. and just to remind people that they are NOT mutually exclusive! after all - scientific thinkers must have an open enough mind to discover something new, right? all of this applies to snake oil stuff as well, by the way.
This test performed by Amirm did not even try to determine the max. output power for (whatever configuration of) multitone signals. He's just been measuring THD at a predefined 5 W output.Dont pay attention to scientific audiophile in this case .
Amirms review of the WiiM amp shows multitone at 5 W and the distortion is very low ( 0,002 % ) even when playing many tones at the same time. Im sure the WiiM amp can give a lot more than 5 W with multitone If the distortion criteria would be 1 %.
i don't really care tbh - i don't place too much emphasis on any one opinion that i encounter in the wild.Dont pay attention to scientific audiophile in this case .
Yes indeed! Where can I sign?And yes, sometimes it is difficult for a German to share and/or understand other languages' between-the-lines.
