SPDIF Output upgrade to 24Bits 192khz
I wonder how the music will change as a result? What special treatment is needed? Finally, this forum is difficult to type on a mobile screen.
This is not a function for upsampling signals. Please set it to the maximum resolution your DAC or amplifier allows. For example, if your DAC spec is up to 24bit/96khz for optical input, set this value. 🙂
Yes no info yet on the fixed asrc. Although in my case I would set it at 24/96 fixed .
