slartibartfast
- Apr 18, 2024
You would need to manually adjust the sub settings. The ability to save a profile including sub settings has been asked for many times.Something else:
let´s assume someone has performed several RoomFit attempts and chooses a profile which differs from the current sub settings (e.g. sub settings are 9ms delay and 180 Phase but the chosen RoomFit profile is based on 6ms delay and 0 degree phase).
Will the Ultra ignore the current sub settings and uses the profile instead? Or is it required to change the sub settings to be in line with the values used in the profile?
