I only just discovered that this is enabled by default in the RC settings. I don't have a separate subwoofer, only 2 speakers. Do I need to do this calibration again to make it right?
It's switch is to select whether or not to add frequencies below the crossover value of the subwoofer setting to the RC.
Therefore, if the subwoofer settings is off, the crossover value is disabled because it does not exist. In any case, if that switch is on, it does not matter because the RC can contain all frequencies.
(If I'm wrong, I know someone will correct me.)
But if you are concerned about it and have enough time I suggest you run the RC again.
