wiimamp user
- Jan 12, 2024
If you set the crossover to let's say 80Hz what will subwoofer calibration do?
That's exactly what I think is one core problem at the moment and the reason that we see things like e.g. this:If you choose a frequency range for room correction of for example 20-300Hz and a target curve, then the algorithm needs to be able to match the level of the corrected range to the uncorrected level of the response above 300Hz so the overall result fits the target curve. I wonder how the target level is chosen by the WiiM algorithm. Presumably microphone inaccuracies outside the chosen correction range will affect overall result.
WiiM's way of using shelf filters without using shelf filtersThat's exactly what I think is one core problem at the moment and the reason that we see things like e.g. this:
A +4 dB "Peak" filter with a Q of just 0.1! What this really does is simply boosting almost the entire frequency range chosen for correction (33 Hz to 3300 Hz in this case). Let's watch this isolated from the other filters:
This is from a stereo "calibration". I'm pretty sure that an incorrectly determined average SPL is the root cause. In particular it looks like the typical silly peak between 8 kHz and 16 kHz found with most smartphone measurements might have been taken into account, although it is far outside the correction range.
I still have to think about how independent L/R "calibration" can be affected under different conditions. How likely is a full range channel imbalance of e.g. 2 dB? I agree that this should be taken care of first, but how should automaiRC approach this? A sort of imbalance over a wide frequency range (but not necessarily the full range) is probably more likely.
Two approaches come to my mind:I still have to think about how independent L/R "calibration" can be affected under different conditions. How likely is a full range channel imbalance of e.g. 2 dB? I agree that this should be taken care of first, but how should automaiRC approach this? A sort of imbalance over a wide frequency range (but not necessarily the full range) is probably more likely.
Just got a updated WiiM Home App. In the release notes I see this!
"External Microphone Calibration File: Import calibration files for improved Room Correction accuracy."
But no further instructions seems to be available.View attachment 17324
It didn't show up in an update check but when I searched for the WiiM app it was available.Just got a updated WiiM Home App. In the release notes I see this!
If you plug a mic in then some new settings appear in "Room Correction" settingsJust got a updated WiiM Home App. In the release notes I see this!
Were you using the phone mic? If so I am not surprised at all.I compared the WiiM room correction with the Room Perfect function of my Lyngdorf amp… the result was not surprising for me as you may guess… using a phone and doing one measurement from one position simply is not satisfying.
Yes I did… just out of curiosity… having a Lyngdorf amp, i don’t need the function of the WiiMWere you using the phone mic? If so I am not surprised at all.
Not yet available for IOS, unfortunately...If you plug a mic in then some new settings appear in "Room Correction" settings![]()
RoomPerfect is on an entirely different level, but that doesn't make WiiM room correction useless. Good to see some progress regarding the cal file import.I compared the WiiM room correction with the Room Perfect function of my Lyngdorf amp… the result was not surprising for me as you may guess… using a phone and doing one measurement from one position simply is not satisfying.
That should simply be a part of the device name.BTW, what does "Gain: 18db" mean
