It is very well organized and wonderful.
You're right.I'd put WiiM 2 beside the LSX with the connection panels and use optical to minimise any delay or airplay transmission issues
The LSX are not near by, so connecting them via optical to Wiim 2 is not possible. The idea is that the further away speakers are not wired.Why sync issues if the WiiM devices are grouped "to play syncronously" as per the app screen, and if WiiM 2 is using its optical out into the LSX?
In my diagram, I had WiiM 1 co-located with the Yamaha, and WiiM 2 co-located with the LSX - the WiiMs don’t need to be in close proximity to each other, they just need to be on the same network. Given that the LSX speakers both need to be mains powered, I’m struggling to understand why WiiM 2 can’t be located close to where they are, remote from WiiM 1 and the Yamaha.The LSX are not near by, so connecting them via optical to Wiim 2 is not possible. The idea is that the further away speakers are not wired.
What delay are you expecting and compensating for?How's this for a creative solution?
Add another WiiM into the tape loop of the Yamaha receiver to add the desired delay to the receiver system.
You have a point hereIn my diagram, I had WiiM 1 co-located with the Yamaha, and WiiM 2 co-located with the LSX - the WiiMs don’t need to be in close proximity to each other, they just need to be on the same network. Given that the LSX speakers both need to be mains powered, I’m struggling to understand why WiiM 2 can’t be located close to where they are, remote from WiiM 1 and the Yamaha.
The difference in arrival time between the speakers attached to the Yamaha receiver and the KEF wireless speakers. Do you think this will be an issue?What delay are you expecting and compensating for?
If the tape out from the Yamaha into WiiM-1 does incur a delay in the audio sent to WiiM-2, then I’d suggest then feeding the sources into WiiM-1 instead (perhaps even thru a passive 4way box as I linked to above), with WiiM-1 feeding the Yamaha while it maintains sync with WiiM-2. Using the optical cable from WiiM-2 into the LSX should minimize any delay at that end, although if the sync mics on each WiiM are doing their jobs perhaps even that shouldn’t matter.The difference in arrival time between the speakers attached to the Yamaha receiver and the KEF wireless speakers. Do you think this will be an issue?
Regardless of what you send in to the wiim via the 4 way switch, it all comes in via the single analog in.Thanks for the encouraging words, Brantome.
A break is in order indeed. Besides, I work for a living.
Unfortunately I still have more questions:
Will I need to re-adjust the delay settings in the Wiim app whenever switching sources (this assumes the switching is administered via aforementioned four-way switch). Wouldn’t the delay adjustment/setting have to be different when I play Spotify vs when I play the TT?
Since it’s an analog source, what happens exactly with the TT signal when it goes through the Wiim 1 first? Does the Wiim know it’s receiving an analog signal and that it’s feeding an analog amplification and therefore just passes the signal on as is, unaltered, but is smart enough to automatically recognize that it needs to convert digital to analog when playing Spotify?
Also, wouldn’t the Wiim feed the Yamaha through the same intake for all sources, instead of taking advantage of (for example) the Yamaha’s phono stage (which is one of the best adjustable phono stages I’ve heard so far)?
Even if that all should work out, I keep wondering if there’s no easier way, with less gear, wires and pass-through stations involved. Just seems a bit crazy.
A more recent high end Yamaha integrated with high-res WiFi built in maybe - and good quality WiFi speakers (if there is such a thing)?
The analog input will always be converted to digital within the wiim. That digital signal can be sent on to wiim 2.
I wouldn't expect you to need to adjust any sync delay once set as the actual source is then immaterial as everything is digital within wiim 1, so line in vs spotify vs digital in etc. are effectively all the same when it comes time to output it.
Yes, you will no longer be using the yamaha's phono input if you plug the TT into the 4 way switcher and the wiim into the yamaha.
Note that you will need a phono stage between the TT and the switcher unless your TT also has a line out.
Let me recap.
All sources (except for the music streaming services, which are received by the Wiim 1 directly via WiFi) first go (via the switch) into the Wiim 1 (line in), where they are converted to digital, and the digital signal is passed on via WiFi to the Wiim 2, which will then feed the WiFi speakers.
At the same time, the same signals that are coming into the Wiim 1 will also be converted to analog and sent via line out from Wiim 1 to the Yamaha, which then feeds the wired speakers.
For the TT I need to add a phono pre before the switch – we keep adding gear.
Possible delay (if any) between the WiFi and analog speakers could be adjusted once in the Wiim app.
If this is all correct, all source signals will first be be processed and converted (at least once) by the Wiim – and that won't result in "colouring" the sound in some ways?
Anyway, the Yamaha basically ends up being nothing more than a power amp feeding the analog speakers.
Is it fair to assume that a lot of the Yamaha's sound signature is defined by how it handles the intake of the different sources, even before they're amplified? Wouldn't I loose a lot of its sound signature (most obvious with the TT of course)?
Yes, since you are only comparing Yamaha and WiiM sounds, you can also measure with the phone's built-in microphone. If you are interested, please give it a try.Microphone? Measure the sound?
