For me too! I have a decent T+A dac and using USB out brings quite an improvement (to be honest I was quite surprised by how much!)Swapping from coax to usb to my Denafrips Ares ii made a very noticeable difference to me. I'd argue the USB out alone makes the upgrade to the Ultra worthwhile
USB can be either synchronous or asynchronous and Wiim supports both modes. Async is most common.USB is asynchronous data package transfer, while SPDIF Toslink and Coax is a PCM synchronous bit stream.
Updates? Thank youThe Ultras are on sale today, so ordered one, it will arrive Friday when testing continues
Updates? Thank you
Can’t you continue to use Amazon Music on even a Mini and use its digital output into the Nano, or wouldn’t you rate it as a transport in such a setup?In my opinion the Nano was better .... I've been and still am a huge WiiM fan (3 mini's, 3 Pros and a Pro Plus) and will continue to use them in all non critical listening and multiroom situations but the Nano just sounds better which means I've also had to switch from Amazon Music which is a pain to Tidal.
I think my summary is WiiM is way better for usability and integration with Alexa etc. but for pure sound the Nano has the edge but would encourage anyone to do their own trials as everyone's ear / preference is different.
I think the Nano's toslink is an output only.Can’t you continue to use Amazon Music on even a Mini and use its digital output into the Nano, or wouldn’t you rate it as a transport in such a setup?
