I totally get that this is primarily a network streamer, but if it had a low-latency mode and USB-input option you could also use if for PC/Laptop Audio and have a single box for everything on your desk.
I currently run a Behringer UMC404hd into an analog amp which gives me MS Teams Audio with almost no lip sync issues on Teams calls (and I can also stream from desktop Spotify etc).
Was looking at Amp Ultra as a replacement with better quality streaming plus option for Teams calls, but if obviously can’t do that at the moment.
PS.Obviously the low-latency mode would need to be set by input source, and understanding it may need to disable DSP based on current architecture, but that wouldn’t be an issue for windows purposes - you’d do pC input with a flat response, and stream with RC+EQ.
Upvote
