USB output
Sdipiet
Just got the ultra and when I plug a USB cable into my dac And look on the output options the USB is grayed out, and I can’t even choose it. what do you think is going on? Thanks.
I have tried a different cable, no different. Audionet dnc. It’s an older item I got used recently. The coax works fine and when i plug in the cable it shows 48k but says unlocked which seems to me means it’s not locked to the Wiim which makes sense since the option for the USB is grayed out on the device and doesn’t even appear as an option in the app.
