Volume control weirdness
AlunS
Has anything changed in the app regarding the connection between the volume on the device, in my case a WiiM Pro Plus, and the volume control on the phone?
I'm fairly sure that in the past, if I was listening to something on the WiiM, that I could adjust the volume control on my phone, and it would only affect the phone and not the WiiM, and to adjust the WiiM volume I'd need to have the app in focus first.
Now it seems that there's a link somehow. I generally keep the media volume on my phone turned down to zero, and only turn it up if I want to listen to something like a video on Facebook or something, to avoid loud surprises from stuff on websites automatically playing. If I do that now it not only increases the volume on the phone but causes the volume on the WiiM to increases as well.
I should note that I have recently updated my phone from a Pixel 7 to a Pixel 9, and also to Android 16 if that makes any difference.
What
What is your settings for "Allow playback ..."?
If on, then the WiiM will follow the phone volume
Thanks, that worked, although it's not very obvious from the description of the setting.
Yes, the logic of the descriptions in the WiiM Home App is sometimes hard to get.
Glad it worked.
I also have it turned off, as there is a major bug in how the volume control works.
