What happened to audio settings?
Tacty
Active Member
when i went to change line out level, nothing happens? i tried to set up between 2vrms to 200 mvrms and there are no difference? lately i have some problems with slight distortion while using eq, and try to change line out level, but things stay the same...
wiim pro connected to external dac via coax cable...last month i was trying the same thing, and every step has audible changes...now, whatever i set, line out level stay the same...
Are you using the Line output?
Line output level is for Line-out. It does not work with coaxial or optical.
If you experience distortion with EQ and you're not using the analogue output at all then the problem is on the digital side for sure.
Go to device settings => Audio Settings => Volume limit and reduce this value. Start with a reduction of 1% per each 0.6 dB of gain you might have applied through EQ.
