Schmidlapper
- Nov 4, 2023
I have submitted a help ticket and feedback on this repeatable issue with a video showing it happening. After editing a PEQ I saved the settings it has separate left and right settings. I opened audio settings to verify that the master volume setting was correct, when I returned I noticed said I was using a custom PEQ setup instead of the one I had created, called test. When I reselected the correct settings I noticed that the left channel settings were now just copies of the right channels. I fixed the channel and saved it again and verified that the changes were made and where holding, they were. Thinking maybe this was a one off I again opened the audio settings page and again when I returned it showed a custom PEQ, results were the same. This was quite frustrating as it takes awhile to manually re enter 10 lines of settings and it leaves me constantly wondering what if something else has changed. WiiM support asked me to make a video of the issue and I easily was able to replicate the results. I just opened EQ settings and saved the current settings with a new name , then opened Audio settings and it did it again, but this time it affected both the test settings and the original settings I copied. Here are some other factors, music has always been playing when I have attempted it, there has always been another saved set of settings at the top of the list which hasn’t been affected. I don’t know if either of those have any bearing on the issue. I have had to redo the settings often enough that I'm not keen to do more tests. As a matter of principle I expect saved settings to not change on their own, especially due to random navigation. If no one can replicate the results that is fine, I have my video saved and will hope WiiM can fix my issue.
Here is the video.
Here is the video.
