A CD transport with all the streaming capabilities and USB, optical and coaxial outputs.What products would you like to see based on what you've experienced so far?
And I am talking about a digital device (no DAC)A CD transport with all the streaming capabilities and USB, optical and coaxial outputs.
I don't know if it's a product or a software update. I would like high and low pass filter options that can be configured separately for each wiim in a group.What products would you like to see based on what you've experienced so far?
Therefore one wiim with a high pass filter can drive bookshelf speakers, and a synched wiim with a low pass filter can connect to a subwoofer.
As for your wiim amp it needs pre outs and line outs so that it can support multiple amps.
Wimm pro plus 2:
Auto room correction with an external usb c mic (attachable to a phone)
10 bands peq
Balanced out
Sub outs
and better dac and better wifi...
This will be the ultimate 2.2 streamer/dac for an audio room.
No objection here!I’ve corrected that for you.![]()
Forgot the Wimm?I’ve corrected that for you.![]()
or WiiM TNGAs what stated before, all additional features will be after ultra. They may call it ultra ll.
There's an assumption that removing features makes things cheaper, and it stands to reason except… Fewer features renders it more of a niche product, and the producer has to charge more to make it worthwhile.Here's another idea:
WiiM Amp Mini
A mini amp would ONLY have amplified speaker outputs, no wired inputs, no other outputs and potentially can only be added as a linked wiim in a group controlled by a pro or pro plus or wiim amp
This device would cut as many features as possible to get the cost low while allowing it to power speakers as part of a WiiM group.
Someone could then have a full WiiM Pro or WiiM amp with their inputs controlling the group and place wireless, cheaper WiiM amp mini's around powering passive speakers at low cost.
Effectively the equivalent of attaching a WiiM mini to a cheap power amp like a Fosi v3, but at a lower price point by cutting out everything not needed for that purpose
Correct!My dream Wiim Amp would have ethernet in, speakers and sub out and nothing else. But I'd be the only one buying it…
Well sure, but for the sake of argument a Wiim mini is $80-90, a Fosi v3 is about the same price, so put it together and you're paying $160 to $180. A WiiM Amp is $299.There's an assumption that removing features makes things cheaper, and it stands to reason except… Fewer features renders it more of a niche product, and the producer has to charge more to make it worthwhile.
